Have you tried it? I have a JAMMA adapter for Track n Field. While the board boots up just fine, I've found that the lack of joysticks on TnF means that the buttons inputs ended up being mapped to the joystics inputs on JAMMA, so you run by moving the joystick back and forth. I'm going to change mine so it works with the buttons of my cab, but not sure if yours has the same issue or not...
