Track & Field
lgsteelers
Donor 2025
Upland, California
Finally got my T&F running w/ a power supply from Todd & TNTAmusements!!
Thanks Todd and also thanks to Fly who helped test out the board & power supply!
Does anyone know how to reset the high scores and all the best times/distances, etc?
Also, the game is missing this fuse but has always played without it....what is it for?
Thanks everyone!
One of the dip switches controls the high score save. Switch 2, #5. Flip it, power up the machine... it'll erase the table... power it down and flip it back to keep the table while powered off.
If the high score table gets garbage in it you'll need to replace the battery.
Haven't had a chance to try this out yet but thanks for the info!
Btw, where is the battery located?
any idea on whether that fuse is needed or what its for? wires are running to it but not sure what the function is....
tks!
tks!
It doesn't look stock to me. Take the fuse out and see what doesn't work any longer. Might be the marquee light, or a fan, etc...
tks!
That Fuse is only needed if your running off of 220volts. If you look close there should be a jumper wire(the white one) running from one end to the other of the fuse holder. When you convert it to 220volt,you cut that jumper and use a fuse. If the game uses a 3amp fuse for 120volts,than you would use 2x 1.5amp fuses for 220volts.
