Track & field sound problem.
jj mann
Clarksville, Indiana
I have a Track & Field that I just got recently. I opened up the back and took the PCB out of its cage and reset some of the dip switches to make it Free Play. I also changed some of the other dip switches to change difficulty. I put everything back in and set the edge connector and turned it back on. Now for some reason the sound has quit working. I took and reset the dip switches back to the way they were before and still no sound. Any suggestions on what might have happened?
Also check the the edge connector on the board is clean, the +12 and/or speker contacts might not be making a good connection.
Then again, it may be a game board fault ...........
