Track & Field restoration.
J67AB
Donor 3 years: 2012, 2015, 2023
Joplin, Missouri
Started out with a junked T&F cab.
cab only and parts of the power harness left in it, no metal pieces whatsoever.
Scraped the cab of the black latex paint, as practice worked on saving the sunburnt artwork that I was going to replace anyways
Sourced parts from PA, NJ, AR and MO. Was able to get most everything in.
Got to work on the coin door, The pre and post novus treatment.
Repro Centuri badge is awesome! Bought the reprobadge from Aztecf, best shipping I have ever seen! EBD2CB4D-B27D-4272-9216-C52370E9A475.jpeg
door is rattlecaned with Rustoleum semi gloss two coats at about 2ft, then the "Williams Splatter" technique of half pressure on the nozzle to get a splatter effect for texture. Takes some practice to get the hang of it, Love the look.
A little bondo corner work on one side CD3D2C06-19B0-4FF6-B1E8-EA19D122B7AA.jpegthen some paint! And side art from Phoenix Arcade
Got a piece of plexi cut, led bulb from Wal-Mart in the original marquee light setup and new marquee from Phoenix, shaping up!
Next was the harness, went Jamma with a Riddletv TracknField adapter.
found an OG transformer which along with a new switching power supply brought life back to the game!
Very nice. Do tell more about the coin door - powder coated? where'd you find the Centuri badge? Looks awesome. :)
Pics of the interior would be nice to see too ...
Repro badge is from member aztecf, coin door was wire wheeled with a drill and then Rattlecaned with Rustoleum Semi gloss and then several coats of the Williams splatter technique.
Repro Centuri badge is awesome! Bought the reprobadge from Aztecf, best shipping I have ever seen! View attachment 470415
Wow, great door!
Looks amazing. Any chance you would share the measurements of the side art placement. About to do mine and I can't find them anywhere.
