Track and Field
tordyvel78
Malung, Dalarna, Sweden
Hello there.
Can someone post a picture of the rear of Track and Field cabinet? I need the location of the power switch.
Can anyone help me?
Hello there.
Can anyone help me?
well I"ve had 4 or 5 track and field/hyper sports cabs and none of them had that configuration.
The on/off switch should be up on the top near the middle/back. A single metal switch with a much smaller mounting plate.
maybe someone else can chime in with a different answer, but I've seen a few of these cabs.
sorry it's just 1 quick picture, I'm not sure where the keys to the back door are right now.
Anyway, as you can see it's a single push button. It is mounted to a small metal plate on the underside.
and I was wrong before it's towards the front of the cab not the back.
Maybe some cabs are different, don't take my word as gospel, this is what all of them that I have seen looked like though.
edit: with all of that being said, it looks like you could probably mount the on/off switch you have there and make it work.
Okey, thanks guys. Things clear up now. The power switch is located on the top? Like
the Gyruss cab?
Maybe Track and Field and Gyruss have identical backs?
Can someone confirm that?
I've attached a picture of my Track & Field (to be restored).
Looks like its just like the Gyruss
