Track and Field Player 2 Issues
BDockham
Gilford, New Hampshire
Finally scored a Track and Field today. Tinkering around with the game, I found that the jump button on the player 2 slot was having issues. The jump button works to enter the initials, but when running for the long jump, before the jump line, the player stops running (keeps moving though) then stumbles into the pit. It doesn't seem to matter how many times you hit jump, this happens every time.
I could understand if the button didn't work at all, but this seems weird. Any suggestions?
I would do something like move the wire from that particular jump button to one of the run buttons and see if the problem persists.
If it does persists then it could be an issue with that wire, or the board.
If it jumps when you change wires, then you know it's something finicky with the button.
