Track and Field monitor rotation?
Ghostlyguy
Donor 2013
Can you rotate the horizontal monitor in a Track and field cabinet to vertical position? Is there enough clearance space, or mounting place inside? Any help regarding this is appreciated. Thanks!
Ghostly :cool:
T&F
I have never done it but I was working on one today and it looks like you could since there are metal brakets that hold it in instead of a shelf. Just make sure you check the clearance between the monitor neck and the back door.
I have to ask, Why would you want to?
I need a vertical jamma cabinet in tucson to trade.. and all I can find is a jammatized T&F cabinet for $75.
Could you take some measurements between the monitor neck and the back door. As I don't have the cab in my possession un-till I finds it's suitable. Thanks! :eek:
