Track and Field button question
Florida
Which should be wired to
run-1
The left or the right?
Doesn't matter as long as you get the players right. There should be a 1 player run 1, 1 player run 2, 2 player run 1, and 2 player run 2, etc. I think I made the left run button run 1 and the right run 2 just because.
Ok thanks that's what I did also. I wasn't sure if there was a "proper" way. I have ocd about that stuff.
Maybe if someone has a factory cabinet they might know.
Mine's a dedicated cab. First picture is of the 1-3 player side, second picture is the 2-4 player side. I'm pretty sure I kept it all like it was originally when I fixed it up. You can see remnants of the tape I used to mark what goes where. Just remember you're looking at it from the back of the control panel is these pictures.
Player one - Run 1 is labeled as orange wire on the schematics so that helps me out.
So I'm assuming that player one run 1 is at the far right if your standing at the machine.
Thanks for the pictures
Correct; far right. Again I don't think it matters as long as you have the players correct. I guess that's just how mine ended up. :)
If you have OCD then you might want to re-look at your buttons. The start buttons were white, blue, white and blue. All four run buttons were red and the jump/throw buttons were white.....I believe the control panel was held in place with a carriage bolt.
