Track and Field 10697 coming back
Cashdog
Donor 7 years: 2013, 2016, 2019-2022, 2024
Golden, Colorado
Picked up this Wonderboy in a Track and Field cabinet. The guy I bought it from was a tech at the arcade in the 80's cant remember if he said Southland Mall or Cinderella mall in Englewood Colorado. Wonderboy was his favorite game, so when the operator went out of business he bought the game. He has had this game in his home since the late 1980's.
I found this in the coin box.
Looks like original Control panel harness is complete op did not hack it up.
Used heat gun and Scrapper to get the old CPO off. Will need to fill the hole in the middle.
Got these wire drill brushes from Harbor Freight to clean this up and the new CPO from Phoenix Arcade
Got panel cleaned up and used JB weld to add a piece to the underside of the panel then planning to use bondo to fill the hole and sand it even with rest of panel.
Hope this works
JB weld worked fine. Little bondo and 120 sand paper and panel ready for overlay.
Got the harness done and the board to boot and play has a burnt pin. that needs to be addressed, the Marquee light works
Trying to decide if I put on side art or not. got to hot too do much more until next week..
Prepping for side art. Anyone know if bolts go under side art or through?
Bolts go through
Anyone have a PCB cage for a track-and-field?
Not perfect but nice. 1 side done. No bubbles. Measured and traced. Once art pealed off backing was a little smaller than I thought.
