dukesilverfan
Traces lifted (but still connected) on neckboard - WG K7401
I was about to start my cap kit last night, when I noticed the transistor heatsinks seemed loose. I quickly discovered that all 3 had lifted the traces on the backside. They are still connected, and the monitor still worked before I pulled it apart, but the colors would sometime cut in and out. This is probably at least partially responsible.
Here is a short 8-second video I took:
https://dl.dropboxusercontent.com/u/18769305/lifted_traces.MOV
As you can see, the traces are still whole, they just lifted up off of the board. Should I try gluing them back down? Will superglue hold up to the heat created?
What would you experts do, please advise!
