Touchtunes amp
copious
Sparta, New Jersey
Help I bought a touchtunes genesis for home added a windows pc and loaded mp3s. While I look for the best touchscreen juke I was trying to start the boss amps installed in the juke. I tested the parralel port and sent strobe signals to no avail, there is another connection that might start the amps.
My question is can I use these amps or should I just buy a new amp?
u do realize that the touchtunes amps are driven blanced right ?
what this means is we use a cat5 cable between the controler (jcb) and the amp
what u would need to do is un-blance it with a (di-box) downlink box
u would also need to power the di-box
this is the box in question https://na.suzohapp.com/products/jukebox_audio_equipment/700168-002
to power it
u will need a 12vdc adapter
open the di box
and u will find solder lands for 12v
ed
to power it
open the di box
ed
The Bose amps in the genesis have rca connections, which I would assume means they are line level. Not having the tech manual, I'd be only guessing tho. I'd also guess that maybe there's a mute signal somewhere that needs tweaking.
