Tornado 355 in 1 won't let me select VGA?
br549autosales
Donor 2012-2013
Foley, Alabama
I have a Tornado multi board that I can't get to work on a LCD monitor, I hooked it up to a test CRT and I can't change the setting from CGA to VGA, I select it under dip switch settings on the screen to change but I can't change it by left or right movement of the joystick. It has 2 dip switches on the 355 in 1 board marked 1 and 2, do they need to be set a certain way?
Do you have the manual?
I assume that your CRT is CGA (do not change the dip switch when the board is running)
Turn it off and set the dipswitch No1 on switch 1 to on for VGA (page 7 of the manual).
it is the furthest dip switch from the VGA connector.
Good luck
Regards
halo1963
Wasn't there a thread about dip switches that were defective on the 1 n 60?
You might want to use a meter to verify that the dip switch is working properly.
