FS Parts: Top Fire Joysticks (Ninja Gaiden, Silk Worm, etc.)
Jano18
Donor 2020, 2023
Top-Fire Joysticks used on games like Ninja Gaiden, Silk Worm, etc.
$40 pair shipped in the US or pickup in Macomb, MI
PM me if you're interested
Will these work in place of a mad planets flight stick on the Jrok board? If so, I'll take one.
I have had a MP flight stick before. It's a different bolt pattern, so you would have to make an adapter to bolt it to the control panel. Otherwise, you could probably make it work but that's entirely your call.
I've got a Krull with a JROK on which I used top fire Wicos for both sticks in order to get fire buttons for games like Mad Planets. I can confirm a top fire joystick will work with the JROK playing Mad Planets.
2 more sold.
Still have some left.
So I received these yesterday, but I am a little confused. I owned a pair of Ninja Gaiden top fire joysticks and they were a lot bigger and more heavy duty than these. These seem like some sort of mini toy crane or candy crane joysticks. They seem nothing like the Ninja Gaiden sticks that I had. I was under the impression the joystick mold was the same as the tall skinny Krull sticks with the added hole for the button.
Here are the 2 sticks I sold about 5 years ago. Looking at mine again though I don't think mine were original either. Somebody mentioned they might've been Happ top fire sticks. Either way the base plate seems much larger, there is no big plastic cylinder above the base and the stick seems taller:
Those are the same joysticks, except the ones you had have an upper mounting plate.
@Phetishboy Here's my original response from your first inquiry.
