top draw poker machine, please help
or at least let me know the model of this machine so i can look up the manual. i looked on google for top draw poker manuals but i couldn't find any. i am new to this so i can't find what i am looking for.
THat's a poker manufactured by SMS or Kramer ( they are both simular ). I'd start off by looking for those.
i found out that this machine is old and is from the 1980s so it is hard to find the manual online. i can't find it on ebay neither. anyone here knows how to program it? the game works but i would like to change some settings.
thanks for the help
thanks for the help
I'm pretty sure you should have an 8-dip switch bank on the board. I'll post the settings later when I find the manual but they will change the %, plays per coin, min bet for jokers, etc.
I know I have a manual for the machine at home. You honestly don't need to find a specific Top Draw manual, just a standard SMS manual.
I can also get you the info you need in case coinopshop can't find it.
Bill
DIP SW
1- ON test Position
OFF
2-3 OFF OFF No Jokers
OFF ON Jokers with Min 8 bet
ON OFF Jokers with Min 4 bet
ON ON Jokers Always
4 - ON Jacks or better
OFF Any pair wins
5-6-7-8 All have to do with % settings. Give me your email and I'll scan the sheet.
DIP SW
1- ON test Position
OFF
ON ON Jokers Always
OFF Any pair wins
i sent you a private message with my email.
thank you
Wondering does anyone here have edge connector pinouts for these pcbs sms/kramer
Have a few of these boards and all just give a black screen when power is applied.
have connected the basics but think i'm missing something.
Sorry for the delay on the pinouts, but here they are.
Blk - PS Ground - 2 1 - PS Ground - Blk
Wht/Yel - +5 Volts - 4 3 - +5 Volts - Wht/Yel
- 6 5 - -5 Volts - Viol
- 8 7 - +12 Volts - Red/Blk
Wh/Red - V Sync - 10 9 - Speaker/Reset Grnd - Blk
Wh/Bl - H Sync - 12 11 - 60 Hz. Gnd (XFRMR) - Blk
Blk - Pabel Gnd - 14 13 -
- 16 15 - Accounting - Brn
-18 17 - Accounting - Wht
-20 19 - 60Hz - Grn
Wht/Blu - Coin Sw - 22 21 -
Org/Red - Play Cred - 24 23 - Reset - Blu
Yel/Brn - Deal Sw - 26 25 -
Org - Discard #1 - 28 27 - Build-Up Mode - Gry
Wht/Viol- Draw Sw - 30 29 -
Red/Blk - Stand Sw - 32 31 -
*Gry - Token Sw - 34 33 -
*Red/Yel - Del Words - 36 35 - Single Coin Limit - Yel
Blu - Discard #2 - 38 37 - Discard #3 - Gry
Wht - Discard #4 - 40 39 - Discard #5 - Wht/Red
- 42 41 - Cancel Sw - Wht/Gry
- 44 43 -
*Yel - Token Motor - 46 45 - Panel - Red
- 48 47 - +12 Volts - Red
Wht/Vio - Speaker - 50 49 -
- 52 51 - Coin-in Meter
Grn - Discard #1 Lamp-54 53 - Video Composite
Blk/Vio - Deal Lamp - 56 55 - Play Cred Lamp - Wht/Org
Wht/Brn - Discard #4 Lamp - 58 57 - Stand Lamp - Red/Vio
Wht/Brn - 25 Lock Out - 60 61 -
-64 63 - Discard #2 Lamp - Vio
Wht/Blu - Cancel Lamp - 66 65 -
Wht/Blk - Discard #3 Lamp - 68 67 - Green - Grn
Wht/Grn - Coin-in Meter - 70 69 - Blue -Blue
Blk - Video Grnd -72 71 - Red -Red
* indicates optional wiring
My apologies for how crude of a write-up this is, but this should help you.
When you turn on the machine, there should be a continuous, steady tone for about 2-3 seconds, and then it boots. If you turn it on and there are random tones beeping, then there's a wiring/voltage issue. Mine has already beeped wildly when the daughterboard wasn't tight on the motherboard.
Bill
Thanks Ripweade for posting these i have searched for a long time for them.
I appreciate it.
connected up the extra 12v at 47 but still a no go for any of the pcbs
all give a continuous steady tone but nothing on screen and tone never stops.
pcbs still expect something connected apart from power and monitor
before it will boot.
just have to figure out what.
thanks for pinouts they will help
I appreciate it.
Definitely something isn't right. If your board has a daughter board (which Top Draws do), make sure it is seated TIGHTLY into the spot. Also make sure that the chips on the daughterboard are the right ones.
I once swapped around some chips to turn it into a different pokie (which can be done) but must've mixed up the chips. Flipped the switch and beeeeeeeeeeeeeee.... Non-stop tone. Put the chips back to the right ones and it worked.
Also, use a voltmeter to make sure you have the proper +5 and +12 voltage flowing. These boards can be touchy about that.
Don't give up! You will get it figured out!
Bill
Thanks for the info bill.
these pcbs don't have addon boards, all eproms are on the main pcb.
Is their anything missing from the bottom of those pinouts
numbers go a bit off at the bottom 59 and 62 are missing :O
Let me try this one more time... Heh. :)
-20 19 - 60Hz - Grn
Org - Discard #1 Sw - 28 27 - Build-Up Mode - Gry
Blu - Discard #2 Sw - 38 37 - Discard #3 Sw - Gry
Wht - Discard #4 Sw - 40 39 - Discard #5 Sw - Wht/Red
- 44 43 -
Wht/Brn - 25 Lock Out - 60 59 - Discard #5 Lamp - Wht/Yel
Wht/Gry - Draw Lamp - 62 61 -
Did the manual for these boards also contain the schematics ?
looking to get a manual for these sms/kramer pcbs.
have a lot of other poker pcbs that were based on these types of boards.
so wondering was schematics printed in the manual or are they a seperate thing.
Poker
That machine looks familiar. LOL I have probably touched it. The seller is a good guy. That is a good price on it also.
