Toobin measuments needed
Yodamingus
Donor 2014
New York
Have a TOOBIN missing the two black triangular
Wood pieces above the control panel
I need to know all about them ..
Measurements all around
Are they screwed in or glued
Painted or laminated
Pics .. if you can
Can anyone help ??!!
Bump
Can someone with a toobin help me out
3/4 inch I'm assuming
you can just use black melamine and cut a couple new ones.
Yes. 3/4". Looks like the pic i attached. Clearly someone sprayed the blocks after they were glued in and the vinyl was in place. You can see the black overspray on the white vinyl. I had one for a short time and the same area had overspray. Makes me wonder if that was done at the factory.
If you look closely you should be able to measure out the overspray there and get a fairly accurate measurement of the diagonal to cut. The diagonal cut also has t-molding on it.
