Toei Toei TC-A292N 3 cap list
gibbous
California
Spent some time reading all the capacitors on the chassis for the Toei TC-A292N 3 in my dedicated Point Blank last night - since I'll be needing to cap it anyways. Thought I'd share. Checked it twice. I kinda jumped around in spots. If I knew which circuits were which it would probably make more sense, but here it is FWIW.
WARNING, this list is incorrect. See post #5 for a revised list.
Toei tc-a292n 3
A heat sink seems to split the board in two, so caps are mostly listed by side - flyback side, and the side the adjustment pots are on. Plus the one on the neck board.
Neck bd
C404 - 250v 22uf
Main chass (starting at flyback)
Flyback side
C53 - 50 10
C77 - 50 1
C76 - 50 1
C71 - 50 33
C75 - 16 220
C70 - 35 2200
C61 - 35 47
C66 - 16 33
C55 - 16 100
C105 - 16 1000
C104 - 25 1000
C63 - 50 1
C102 - 160 47
C62 - 250 10
C92 - 35 1000
C115 - 180 680
Adj pots side
C90 - 35 47
C94 - 50 4.7
C123 - 16 100
C88 - 50 2.2
C89 - 50 2.2
C87 - 50 10
C32 - 50 4.7
C28 - 50 4.7
C29 - 16 22
C34 - 50 1
C30 - 50 1
C36 - 50 1
C52 - 250 22
C44 - 35 47
C83 - 16 22
C42 - 35 47
C36 - 16 10
C124 - 16 100
C37 - 16 10
C10 - 50 1
C9 - 16 22
C7 - 16 22
C5 - 16 22
C3 - 16 470
C84 - 35 47
C78 - 16 330
C68 - 50 100
C79 - 35 470
C67 - 35 47
C14 - 50 2.2
C13 - 50 2.2
C12 - 50 2.2
C19 - 16 10
C1 - 16 100
C69 - 35 470
C67 - 35 47
C85 - 35 47
C45 - 16 10
C111 - 100 47
C112 - 16 100
C96 - 16 470
If you can, add all of the other pertinent replaceable part info's, like BP caps, filter cap, HOT, VR, IC's, flyback, etc....
Edited to remove the second C75. List should be correct.
mod - don't know if I can reliably identify all those parts, but I will try.
Does this look like any type of identifying number for the flyback?
attachment.php
Finally went through this and actually tried to replace all the caps, and now I have a revised list to share. Removed some duplicates and errors, and marked the ones that I found to actually be BIPOLAR. I will put a warning on the old list instead of removing it. Pretty sure nobody needs to go back and undo anything, but just in case I'll leave both versions up.
> REVISED Toei tc-a292n 3
> Neck bd
> C404 - 250v 22mf
> Flyback side
> C53 - 50 10
> C77 - 50 1
> C76 - 50 1
> C71 - 50 33
> C75 - 16 220
> C70 - 35 2200
> C61 - 35 47
> C66 - 16 33
> C55 - 16 100
> C105 - 16 1000
> C104 - 25 1000
> C63 - 50 1 BIPOLAR
> C102 - 160 47
> C62 - 250 10
> C92 - 35 1000
> C115 - 180 680
> Adj pots side
> C90 - 35 47
> C94 - 50 4.7 BIPOLAR
> C123 - 16 100
> C88 - 50 2.2 BIPOLAR
> C89 - 50 2.2 BIPOLAR
> C87 - 50 10
> C32 - 50 4.7 BIPOLAR
> C28 - 50 4.7 BIPOLAR
> C29 - 16 22
> C34 - 50 1
> C30 - 50 1
> C36 - 50 1
> C52 - 250 22
> C44 - 35 47
> C83 - 16 22
> C42 - 35 47
> C124 - 16 100
> C37 - 16 10
> C10 - 50 1
> C9 - 16 22
> C7 - 16 22
> C5 - 16 22
> C3 - 16 470
> C84 - 35 47
> C78 - 16 330
> C68 - 50 100
> C69 - 35 470
> C67 - 35 47
> C14 - 50 2.2
> C13 - 50 2.2
> C12 - 50 2.2
> C19 - 16 10
> C1 - 16 100
> C85 - 35 47
> C45 - 16 10 BIPOLAR
> C111 - 100 47
> C112 - 16 100
> C96 - 16 470
