Toei CM-F14 H.Width coil?
Dilandau00
Thousand Oaks, California
I have a Toei 14" monitor in a Taito cocktail cab, the H.Width coil broke off at the base, is there any replacement available for it? It seems like it should still work okay, but I would prefer to replace it if I can. Failing that, anyone have a busted chassis they'd be willing to de-solder one off of?
are there any numbers on it? I have a dead Toei chassis at work that might have one on it...
All I can see is a 2 on the top of the black base, but I could be mistaken. I get 0.4 ohms through the coil measured from the top, and 0.5 ohms measured from the bottom in circuit.
