Toei A20H Chassis needed. Same as for Phoenix upright or need 2SD748 Transistor
barakawins
Donor 2023
Woodcliff Lake, New Jersey
Toei A20H Chassis needed. Same as for Phoenix upright or need 2SD748 Transistor.
This transistor is mounted on the chassis and is a voltage regulator. Seems mine is shot and I can't find a replacement.
John
You can use the more common 2SC1106 (same as the Electrohome G-07) as a replacement. I just had to do this on a Toei.
Edward
Thanks for the reply
Thank you very much for the reply. I guess one of these transistors C1106 is a regulator. The other one is the HOT right?
John
