MaximRecoil
Here is the pinout for Ikari Warriors (44-pin SNK):
Here is the pinout for TNK III (also 44-pin SNK):
So the TNK III board works fine in the Ikari Warriors cabinet, i.e., the joystick controls the tank movement correctly, and the rotary handle controls the aiming of the turret correctly. +5V, ground, RGBS, P1 & P2 start, coin, and speakers are all in the right place as well. However, the two fire buttons don't work for obvious reasons. I have a few questions:
1. If I wire up the Ikari Warrior's card edge connector pins 25 & 26 to the fire buttons (in parallel with their normal wiring to pins 13 & 14) for use with the TNK III boardset, will that cause any problems when the Ikari Warriors boardset is installed? In other words, pins 25 & 26 aren't used on the Ikari Warriors boardset, but with this proposed setup, pressing e.g., the machine gun button when playing Ikari Warriors would close a switch on not only pin 13, but on pin 26 as well. Is this a problem? If it is, I could put a Molex connector in there to easily disconnect the TNK III fire buttons wires when using Ikari Warriors.
2. There is currently +12V on pins 39 & 40. TNK III only calls for +12V on pin 40. Is that a problem?
3. There is currently -5V on pins 29 & 30. TNK III only calls for -5V on pin 30. Is that a problem?
Code:
IKARI WARRIORS
SOLDER SIDE COMPONENT SIDE
1 +5V 2 +5V
3 COIN 1 4 COIN 2
5 SERVICE 6 RESET
7 START (1P) 8 START (2P)
9 UP (1P) 10 DOWN (1P)
11 LEFT (1P) 12 RIGHT (1P)
13 M. GUN (1P) 14 GRENADE (1P)
15 16
17 UP (2P) 18 DOWN (2P)
19 LEFT (2P) 20 RIGHT (2P)
21 M. GUN (2P) 22 GRENADE (2P)
23 24
25 26
27 28
29 -5V 30 -5V
31 32
33 SYNC 34 BLUE
35 GREEN 36 RED
37 SPEAKER + 38 SPEAKER -
39 +12v 40 +12V
41 GND 42 GND
43 GND 44 GND
Code:
TNK III
1 +5V 2 +5V
3 COIN 4
5 6
9 UP 10 DOWN
11 LEFT 12 RIGHT
13 14
15 16
17 18
19 20
21 22
23 24
25 CANNON 26 MACHINE GUN
27 28
29 30 -5V
31 32
33 SYNC 34 BLUE
35 GREEN 36 RED
39 40 +12V
41 GND 42 GND
43 GND 44 GND
