How do you tell if you have a 4 or 2 player TMNT? and can you switch between the two?
I got this thing in a converted Berzerk cab and i put it in my NFL Blitz '99 game and it powered right up...but, it's only showing 2 players? is that just the way the screen is when it starts up or is there a way to change between 2 and 4 players?
I can't do much because the NFL Blitz game has an issue with the joysticks not working...so...all i could do was see if the board was dead or not.
Any help on this is appreciated.
I was planning on putting the TMNT in the NFL Blitz cab and just doing a fresh wire harness all that from scratch...only thing used from the Blitz would be the monitor basically....but, now I am not sure if this is a 4 player or not and if not then there is no reason to put it in the Blitz...I can just rebuild another cab.
here are some pics of the TMNT...maybe that will show what you need to answer? Kinda confused because it only shows 2 player on one screen but shows all 4 on the other?
Also shows it "Hero" turtles? must be the UK version?
