Spinning off a discussion in the Dynamo ID thread; we've discovered a TMNT/Konami labeled cab with a Dynamo ID tag. I'm curious if this is a case where all TMNT and possibly all Konami 4 player cabs were produced by Dynamo or some combination of Konami/Dynamo.
In this thread we have a bunch of pictures of my Dynamo produced TMNT cab; unfortunately the model number is lost on the tag, so at the very least we're hoping that someone else with a Dynamo tagged TMNT can fill in the blanks on the model number. We'd also be curious if those without a Dynamo tag could comment on the general construction of their cab vs these pics.
@DonPanetta
Unfortunately the damage to the tag makes it impossible to read. I see 0208xx400. Maybe some others with TMNT cabs can help.
The rear batons are recessed like a HS-5 and run from the top of the rear plate to top of the bottom rear plate. In my cab, there was a gap at the bottom which I closed up with new material as the orignal was destroyed along with the rear plate:
View attachment 749284View attachment 749285
Ignore the mending plate on the side; that is to reinforce the new material.
The bottom plate has dowels for the side walls and the kick plate. Batons are also recessed. I had to replace the kick plate due to water/mildew
monitor is the standard shelf mount k7000.
Hey @DonPanetta.
I've been going through a TMNT project and I found that it bears a dynamo tag, which I don't see listed here:
It also has the standard Konami tag, but the label clearly says
PROD. FOR KONAMI NINJA TR
Model number is unfortunately hard to make out.
It also has the standard Konami tag:
Here ya go:
Unfortunately there was a ton of damage to the bottom, so I had to replace 10" off the sides, the kickplate and the rear plate. The rear plate was odd in the it was MDF, not particle board like other examples.
Not sure about other ones, but the sides and kickplate used dowel construction like HS-5/9s.
Was also missing the door so I made a new one. Other than that it's the same as others I've seen. Note the CP was chopped off by someone; this was converted to a MK and then a Golden Tee at some point. Side art wasn't salvageable, but was TMNT under the paint:View attachment 749281View attachment 749282View attachment 749280
@DonPanetta
