sugar_ray
TMNT how do I wire coin mechs to match the characters??
Just restored a TMNT cab. It was an NHL open ICE 4 player. all 4 players on the NHL boardset worked just fine. Open ICE also has the addition "start button" where turtles does not. Open ICE was wired up so it didnt matter what coin slot you inserted your coin into you were NOT committed to playing at that slot. Turtles was different. What ever slot you coined up with meant you were stuck at that station.
I have the 3 and 4 player harness that plugs into the boardset.
PROBLEM:
TMNT players 1 and 2 work just fine. How do I wire up player 3 and 4?? right now, coining slot 3 and 4 only adds more credits to 1 and 2. I am unable to play with 3 and 4 as the 3 and 4 coin slot is not triggering these characters??
Lastly.....is there a way to go to on screen settings with TMNT?? If so how?? My open ice was rigged with a toggle switch. Once flicked the boarset would give you on screen options. This toggle switch has no effect with the TMNT board in the cab. Perhaps a pin out diagram from PCB to coin mech???
thanks!!
PROBLEM:
thanks!!
