Title Page issue with rowe cd100k
Gamarule
California
Hi everyone I'm new to this forums and also new to jukeboxes, i have teach my self a little by reading around and i have found lots of the answers for my questions in this forum, so thank you!
my current problem is with a rowe cd100k that i bought at a yard sale as a project because it was not working long story short i replace the amp and repaired the cd-pro drive and is now playing beautifully , but now is the title page, originally i will press the up or down button and i will get a noise only but it wouldn't switch up or down the pages, but i was able to move them manually using the manual turning option, so i removed it from the jukebox to try to clean and grease it and to check the motor as i thought that was the problem, i removed i few parts from the side of the title page and grease them also looking for loose parts that needed to by tight also replace the little board attached to the motor where the power and computer connects, after that i went ahead and test it and for my surprise it worked ! it was able to go up and down but heres the issue : once i reach the very last page from the top or the bottom it get stuck and won't move anymore just a weir sound, i have to manually switch the first or last page to make it work again, what could be happening?? again it just happens once it reach the first or last page, in between them works perfectly and strong.
any ideas would be greatly appreciated thanks in advance.
There is a switch on the side of the page mechanism near the motor that lets the jukebox know whennit reaches the end or the start, if that switch is bad or not making contact properly etc it can cause that, but if its making a weird noise that makes me think its the motor trying to turn the page and cant, which can happen from misalignment and or broken plastic tabs on the pages that help each other move. If its a mis alignment problem then that particular model H J K where they used the vertical pages it is a nightmare to get them aligned properly. Can also be broken teeth on the plastic guides or gears either side of the title page mech.
