vintagegamer Well-known member Donor 2024 VAPS Joined Sep 1, 2007 Messages 21,105 Reaction score 2,611 Location Bear, Delaware Jun 29, 2024 #1 Like the title says, trying to remove glue adhesive from a surface with a silkscreen graphic on it. I've read Goo Gone can remove paint so I'm looking for alternatives. I've tried a little wd-40 but not sure that's the best path forward.
SCUBA King Well-known member Donor 6 years: 2020-2025 VAPS Joined Dec 3, 2020 Messages 9,356 Reaction score 7,846 Location South Lyon, Michigan Jun 29, 2024 #2 YMMV but I would try 99% Isopropyl. If it is silkscreened paint, should be fine, if it is reverse printed ink it will dissolve the ink for sure.
OP OP vintagegamer Well-known member Donor 2024 VAPS Joined Sep 1, 2007 Messages 21,105 Reaction score 2,611 Location Bear, Delaware Jun 30, 2024 #3 Canola oil seems to have done the trick!! Thanks all for the input!!
