Zinfer
Working on an Atari AR1 board, basically just running a cap kit on it. It's for a Lunar Lander.
Question: Can anyone tell me if a 2n6107G is a cross reference for a Tip32?
The specs call for a Tip32. Now I have Tip32's in stock however I received this 2n6107 as part of a cap kit for it. I'm unsure it's wise to use it as I have looked up the specs and they aren't at all the same or even nearly.
I'm also having to order some additional 1000uf25v and 10uf25v axial caps as the cap kit came with 3300uf's and no 10uf's for Gods sake. It'd probably work fine for an ARII..but I did specifically say it was for an AR1.
I can handle the caps just fine but that transistor looks like it could blow up my work.
