Bullwinkle
OK, the subject should read "TIP 110 suitable replacements?" not TIP 100
I'm working on a Gorf and two of the lights on the "rank" display board are out. It looks as though the TIP 110s are toast for the two lights. Will any of the following NPNs work properly in it's place or do I need the 110?
TIP 102, TIP 120 or TIP 122
Also, does this work like a cap where voltage can be higher, but not lower than the original? (ie: the 110 is 60v, the 111 is 80v and the 112 is 100v) Is there a rule of thumb on these?
Thanks,
Tom
Thanks,
Tom
