verymotley
The game is a time pilot that was converted from a crazy climber cocktail before I had it, as you will see in the pictures they used a weird adapter of some kind between the pcb connector and the connections, I dont know why but the game played great so I just left it. The extra connector finally cracked so I figured I would just remove it and attach the wires to the pcb connector and carefully traced back each wire and labelled them so I would hook everything up right. Well the result was a distorted picture with nothing working right and then the power supply started to smoke, I have no idea how I did that but now I cant even turn the game on to check voltages or anything. What could go so wrong to cause this?? It seemed like such a simple fix...any ideas about what caused this???
