Time Pilot '84 Harness?
simpsons99
Snohomish Washington
Time Pilot '84 Harness is that the very samething as a Scramble one?
I have been looking for a Scramble one for years . I think i might have found one if it's the same as this game!
The only difference is the -5v, which in pin A on the solder side. You can just add that pin and wire it yourself (or just move it from one of the coin counters). Scramble, I believe, needs it for sound. Tp84 doesn't use it. Most Konami and Stern games used the same harness. Others that I know of are Turtles, The End, Lost Tomb? and original Time Pilot. May just have to add/move 1 or 2 wires.
TY Lost Tomb is not the same thats the problem i have.
If I may ask, why won't the Lost Tomb work? The pinout seems to be the same and the manual for Lost Tomb says, "This kit will convert the following games: The End, Scramble, Super Cobra, Armored Car, Jungler, Turtles, Amidar, Moon War, and Strategy "X"." Just curious.
The Control Panel Harness for the scramble does'nt work with the Main Harness for the Lost Tomb..
I guess that's why this Harness is Taged Lost Tomb on it? Belive me i've thought this over or i just don'nt understand why it does'nt work with just the wiring from the lost Tomb cp
You can play the game but there is'nt any going down with the ship, I belive Firing and booming was a Problem allso.
It's been awhile since i played it like that .. I know it just did'nt play right. You would think it would with Lost Tomb you can fire and walk all these different ways.
