Time Crisis 4 monitor questions
racerx1690
Wichita Falls, Texas
I have to drive an hour away to fix a Tekken 4 with dual 27" monitors in it. One of the monitors is shot, and I need to know (cause I can't remember from the last time I was there) is the monitor a VGA high/med res, or a std res CGA? What will plug right up to the mainboards without any hassle? Anybody know any of this?
Unfortunately, the only manual I can find is for the UK version, listed with a 27" flat-screen Pentranic of unknown model. It has a 3-pin power molex and a 6-pin video molex...
Tekken 4 will run at CGA or VGA depending on the dip switch settings.
Time Crisis 4 has Nanao or Sanwa monitors in it I believe. The monitors are INSANELY reliable though. If you have one side down you more then likely have a bad power supply on that side or a bad CPU on that side. Good thing is that you have another game right next to the one your messing with! I "think" that the game runs at VGA but I'm not 100% on that. I do know that its next to impossible to get anything other then the factory monitor to work with this game.
Is the game your going to fix a Time Crisis 4 as listed in the subject header or a Tekken 4 which you have quoted in the body of the email?
