Time Crisis 4 ERROR1 problem
Dpac
California
The first player on my Time Crisis 4 all of a sudden come up with a "ERROR1" on the screen. Player two is working fine. When I reset the machine, player 1 would not come up at all, player 2 works fine still.
Anyone have any idea what the problem might be?
Good thing is that you have another side that works so you can swap parts between them. I've never seen Error 1 on any of my TC4's but I'd guess that your looking at some sort of CPU issue. You can swap CPU's to side to side to see if the problem stays on that side or moves. Theres also a chance that your power supply for that side is bad.
The manual says nothing about error 1 BTW.
I could not find any info. about "ERROR1" message. Going to try and swap some parts to see if I can track this problem down. Could be the CPU or maybe the hard drive? Ever had the hard drive go out on one of these? If so, where can one find a replacement for that or any of the others parts like the CPU or the whole PCB?
I've had hard drives fail but they are encrypted to that mother board inside the TC4 CPU so its not something that can be copied. The last time I had to replace a drive it was close to $1000.00 for the repair.
