installed flat screens guns shoot out of range some have said flat screens unless rear projection wont work but i feel it could be a voltage problem +5 any other suggestions..
does TC3 use the sensors around the side of the monitor? if it has sensors make sure they are the correct way up, as if you happen to install the bezel upside down would give that message I believe, also check voltages.
