Can someone tell me if the Timber joysticks are 4 or 8 way? Mine only move left, right, up, and down. It would seem to me that they should move the guy diagonal too but they don't. I have not played this since I was 16 years old! Thanks
Don't own a timber but it uses the same joystick that ms pac uses which is a 4 way. Now if you want to open the can of worms that is the tron 4 vs 8 way discussion I suppose the switches may be able to be tweaked so the actuator could hit two switches at once which could allow the stick to work as an 8 way if the game is programmed to do so. According to the klov archives which is not always correct, it's a 4 way game.
Well, thanks for the heads up. Guess I'll have to find some time to up my score.
You should submit your score to MARP so I can check it out without having to wait on TG.
I've got a 732k 5 man score waiting to be verified. You should give the TGTS settings a try.
It's nice to see Timber getting some love.
