FS Parts: Timber cab with working monitor in MD: 150
GuidoTorpedo
Maryland
Rating - 99.1%
105   1   0
Good resto candidate. I'm keeping all the MK guts, so you'd basically get a cab with a working monitor. The monitor has what appears to be Timber burn in. Pickup only. PM if interested.
-Mike
hmmmm... there a timber bezel under that mk artwork or no? hows the inside look? what what do i do about the control panel at this point? is it salvagable with bondo to cover the extra buttons? or like, whats the deal? i need to see more....
Where in MD are you? Also is that a MK CP bolted to the cabinet? Looks like it would need a new stock CP.
95% sure there is no bezel. Clean on the inside, nothing proprietary to timber though. The panel, I guess put an overlay on it and lexan over top to permanently cover the extra holes, otherwise you need a new cp. You might be able to bondo, but it is thin steel IIRC...
Northern Baltimore County. I believe that is an original timber cp, just someone drilled the fuck out of it.
