Threaded hollow stock use on the new Wm's multipanels?
Thomas
Donor 2021
Virginia
I have been looking for the material used to make the standoff's on the new Williams multipanels. So I can fix the error made on the panel with the latch setup on both sides.
You see they used threaded screws with the head's cut off for the latch base's instead of the standoff's which were used for the wico joysticks.
Any idea where I might find some of this hollow threaded stock?
You see I want to be able to switch out different panels during competition to the original Williams panels and not use the multipanel.
But the way the new multipanel is setup I would need to move the latches forward on the cab. Well this just doesn't work for me. I want the darn latches in the original spot. This was clearly a mistake in the design of the original Wm's multipanel.
Any ideas???
