Hi all,
Another member who has the same cabinet but original artwork gave me the following offset dimensions:
34 1/2" from the bottom, 3 1/4" from the back.
Update:
Yet another member has reported the following offsets.
A short 35" and a short 3"
So somewhere around those values.
I had some problems installing this artwork on a vinyl cabinet. The premask adhesive is stronger than the adhesive's hold on the vinyl, so it is very difficult to remove the premask after installation without pulling up the artwork. However, I finally figured out that after applying the artwork, you can wet down the premask which makes it softer and breaks down its adhesive somewhat.
