Things to check on a dead Sanyo 20-EZV?
Do you have 100V at the outlet in the bottom of the cabinate?
Test the 200mA fuse.....
Yes, it is an extra monitor that I want to get working. I tested it by plugging it into my Punch-Out cabinet. Both monitors currently in it work fine, so the cabinet itself can be ruled out.
I'll do that a little later and post the results (can't do it right at the moment).
Edit: The fuse tested fine. I think I found the problem though (or at least, a problem). The corner of the PCB where L601 is; is broken.
Yeah that's not good!
Are the leads broken? Test leads for continuity on each side of where the PCB is cracked...
If there's no continuity, you'll have to solder on some jumpers across the breaks....
I'm probably not telling you anything you already don't know....
