Thick paint on plexi help!!!!
hucklebuck73
salt lake city, Utah
I can see the artwork, but have tried stuff i need advise...
The best thing for removing spray paint is brake fluid - does not hard plastics, metal, etc and can be washed off with plain water. Learned this from an old model maker.
Now this may or may not affect the artwork, so use at your own risk (maybe try a small area first).
Coolio thanks folks...I have to take it off to clean up the wiring inside so I will try it...I wasnt sure goo b gone would work, but I have plenty of that around...I might try the other stuff as well as a test for later..Thanks again
What are you trying to do? that looks like it's a marquee cut in half and turned into a panel of some sort, not anything original.
Pork: I have asked a few times if anyone has this game or a pic of this and nothing, so I assumed its some artwork hidden under black paint. I just figured id try and bring it out again...You might be right, I never thought of that...I have also searched the net to find a pic of that one area and nothing so far. The rest of the cab is good but this area. If it is a marquee that's a good cut job usually there's jagged edges or something not right..
