In fact, it was fun! Keep the yolk with the chassis and the rings with the tube. I might do this more often! Tube swapping that is...not breaking tube necks, which I hope never happens again.
Those are some respectable high scores (in my house)!
Oh, and nice job on the tube swap as well![]()
Where are you getting the tubes from? Do they have to be old 80's 19" TVs?
My Elevator Actions is screaming for a tube swap.
Luckily the Defender I just picked up had the same model tube with a blown chassis that I wasnt even gonna attempt to repair. If it is a G07, you can use nearly any type of 19" Panasonic tv, or just be gutsy and buy a cheap one and hope the pins are the same layout and the tube neck is the same width. In this case, they were 10-pin necks with a 29mm neck. This is a decent cross reference site: http://www.vidiot.ca/montube.php
How do you pull the yoke off past the purity rings? Do the purity rings have to come off too?
