thebman80
I have a bunch of project games that I really have no use for and I need room so I can get stuff I actually want. At this point I'm packed to capacity and more that half of it is stuff I'm not going to use.
I have 2 empty games a Rolling Thunder and a Buck rodgers.
The rolling thunder is totally gutted but has a coin door.
The Buck Rodgers has a power supply monitor and CP not sure if it has a coin door or not Also has a sega Nano monitor with spare chassis I couldn't get the monitor to work with the one chassis but never tested the other one.
I have a Crystal castles 2 board sets both semi working I have the game wired up and it comes on with sprite issues on the one PCB. I have a spare CP which I thought was going to fit the cabinet but it doesn't I can through that in as well It has no trackball and one side of the cabinet has a crack. I have some money tied up in this one so not really sure if its even worth getting rid of but if I can I will.
I have an upright After Burner cabinet no side art and It needs some reassembling which I might have to do I got all the wiring back in but not totally hooked up. I have the monitor Bezel and CP but the rumble didn't work the motor just spun. I have a PCB I did test I could hear it working but I didn't get clear video out of it maybe it was monitor tweaking that needed to be done maybe not.
I have a Double dragon Honestly I don't like the game its dedicated and its all there and works it has a spare board set that has an error. The red stuff on the side of the cabinet is bondo filler that I filled a scratch but didn't get a chance to sand down the cabinet needs a repaint and a CPO.
