session9
The Machine: Bride of Pinbot ..... A Pinball Restoration Story
This documentation of text and photos is the end of a long journey with this game.
This is by far the most extensive, complete, restoration I have completed to date. Every single bolt, screw, switch, wire, solder connection, you name it, has been gone over, replaced, or upgraded.
An uncountable amount of hours, patience, and labor has gone into bringing this "Bride" back to life.
Some notable highlights of what has been done to this machine......
Upgrades and Restoration:
Original Diamond Plate Playfield w/ Red Center Heart insert
The Playfield has been Professionally re-worked and Clear Coated by Christopher Hutchins @ HEP (High End Pins)
New WPC89 Rottendog Power Driver PCB
New WPC89 Rottendog CPU PCB
New PinScore LED Display
New Shuttle and Heartbeat Ramps
New Skillshot Eggcrate Plastic
New Ball-Lock Plastic
Cliffy Ramp Protectors
New Chrome Bride Helmet
Pinball Pro Subwoofer and Backbox Speaker Upgrade Kit
Every single Bulb (#555, 44, 89, and 906) Replaced
New Shooter Rod Assembly w/ correct tension spring
New Flipper Assemblies, Coils, and Bats
New Flipper Buttons
New Flipper Buttons Switches
All coils completely rebuilt and replaced
New Rotating Head Motor
Completely disasembled, cleaned and Rebuilt All Pop-Bumpers with new parts (bodies, skirts, rings, fiber and metal plates, springs)
Cabinet was stripped and completely sanded down to bare wood, bumps, bruises, and dents, repaired, sanded, and refinished
Inside of cabinet completely disassembled, sanded, cleaned, masked and repainted
Installed All New Cabinet Art
Installed All New Ground Braid inside cabinet and backbox
Installed New Power Cable
Rebuilt Line Filter
All Metal Ball Guides were re-grained and polished
All Playfield and Under Playfield metal parts nickel plated or polished
LockDown Bar and original System 11 Siderails completely stripped, chrome plated and polished
New Lockdown Bar Seal (Bear Seal)
New Playfield Glass
New Legs, Extended Bolts, and levelers
Upgraded Leg Mounting Plates
Coin Door completely disassembled, cleaned, rebuilt with new parts, and re-finished
New Playfield Rubber Kit
New High Polished Pinballs
New Apron Cards
Backbox Lightboard masked and refinished
Installed NOS Mini Playfield
Installed New Serial Number, Caution, Information and Instruction Decals throughout cabinet in original locations.
NOS Translite
NOS Keychain
http://usergallery.myhomegameroom.com/gallery/blechewite
New Flipper Buttons
Rebuilt Line Filter
New Playfield Glass
New Apron Cards
NOS Translite
NOS Keychain
