I dunno, I use the universal card 90% of the time.
100% of the time here.
One thing to consider is that the ICs on the individual cards can fail too. How would you know unless you desolder them or test against a known good IC in circuit?
At least with the universal card you can test the reference IC somewhere else (e.g. an IC tester or a TL866).
I used the HP in the past but now only use my BugTrap as it can test 20pin devices (still has limitations).
P
0.1% here.............
I dunno, In truth having to make up dozens of individual boards is daunting and pricey. Flipping a few dip switches on a universal board seems like a treat by comparison.
The time you spend figuring out what dips to flip (then having to keep track of them, and not make a mistake when using them) can be used to make an individual board. It's basically the same amount of work.
I am releasing the Gerber files for all the cards (repros of the 16 channel dedicated and 16 channel universal, and the 20 channel dedicated and 20 channel universal). I will post the link as soon as I sort through the files and the web page is up.
That is straight up awesome of you. Not enough interest for just HSS to sell them?
