the getaway pinball.i have a problem
kuglerarcade
medina, Ohio
so i got a getaway put a new cpu in it then game worked, didn't play it for like 2 week then when i turn on game ramp jumps like 6 times.i hit the start button and game starts.ball goes into plunger area hit shiftier to launch nothing no launch and then ramp starts jumping again like 6 times.ps i check the transistor its good and i replaced the coil.any help would be appreciated thanks
Try a switch test and see if any switches like the trough are not registering, or you have some that are closed but shouldn't be
The metal ramp is known to crack on them (and/or the linkage, I forget), which causes issues. I remember reading about it when I was researching mine, though I didn't have the issue myself. But if it cracks, it gets misaligned, and won't behave properly. Try googling around for more info on it.
Also, if the sensor is bad or dirty, that'll do it too. It's a pain to get to, but you might need to remove and inspect the ramp.
