mcandrewsoun
Probably the difference in failure rates is due to the LV supply not being in the Amp deflection circuitry. Apparently it really isnt needed, and most of the 6100 failures I see are LV supply related. Im intrigued by the slew rate difference.. Since slew rate is generally voltage per sec or (msec). I saw Ferro magnetic mentioned above..Are you talking about the Yoke? I could see some degradation of slew rate with coupling caps..but it really on comes into play on the output stage,since thats where the big voltage swings are, and it appears to be DC coupled. Its been many years since I took circuit design in college, so I maybe remembering some of this wrong..LOL..
What makes the HV supplies so unreliable? Seems like it actually does less work on a vector HV section then a Raster, since the HOT doesnt actually drive a yoke..
Andrew
Andrew
