Found in the classified section on NextDoor, posted 2 days prior to me seeing it. Literally 5 minutes away. Seller has a Tekken 3 and Capcom bowling also at good prices, but I had to message him...
Is the Paperboy still available?
That line will never gets old.
Even better, he has a contractor's Express van to move it! I just needed to go over and help him get it out of the basement. Hardest thing I've done so far collecting these games.
I've moved a few games at a friend's first house with a similar basement staircase that involves a 90 degree landing turn midway. My friends staircase was wider, as was the landing. This guy's was just wide enough to fit a game down facing you. Turning it on the landing was just painful even with 3 people helping out. The walls took some abuse (and probably a whole lot more when he tries to move that Capcom Bowling out of there, how the hell did it get down there anyway).
I ended up on the top of the moving effort near the end, the game having to be angled oddly to get it into the hallway and the back door was facing me. Once we got it onto the main floor, I just slowly sank back and down onto the floor, with Paperboy on top. Didn't hurt, wasn't a quick fall, and they got it up off of me quickly, but my body (legs mostly) just gave out after all that.
So yeah, I earned this damn game.
Overall the game works, plays fine, monitor is incredible (and as I found out after opening, it's a relatively new tube and chassis) and only has minor dings and stuff along the edges.
So far I've only opened it up to assess everything and do a quick vacuum & wipedown. Normal corrosion on the power block and other metal, but no disasters. 5v on the game board read at 4.9something so that's good news, but I may replace the two big blues anyway when I go to clean and rebuild the power block.
Going to go with the Paperboy beta sideart from TOG, I think that looks stellar.
First photo is seller's posting, second is in his basement.
On with the photos. Repair questions to follow.
- Controller "centers" with a slight turn to the right.
- A support beam under the top of the control panel is broken.
- Was able to pry the back door open and found keys behind the coin door!
- It doesn't look like a Championship Sprint conversion to me.
- No jumped or bypassed fuses!
- Test mode shows ROM Fail at 2D
- Right speaker has no sound
- Odd vertical streak on left side of display
