That's gotta be hard to play.
Most assuredly not an Atari style cocktail...
I'd lean toward Universal perhaps? Not sure. I can't stand the vertical stick orientation on those...
Definitely not Atari
I've got an MC in the garage, and the top is different, and the corner hold-downs for the glass are much different. The legs bolt-on in a similar way to the Atari legs, but the ones in the picture are rounded - Atari used square tubing.
Obviously someone has butchered the original CPs on that one. I wonder what it started out as?
You mean Horizontal stick right? :confused:
Edit: And that CP looks like a kitchen cabinet drawer...
Being that it has a 10p sticker, perhaps it is leyland or elctrocoin.
I have a DK cocktail and the joystick pointing out horizontally isn't too bad once you get used to it. That being said, the game in the auction isn't even a real Pac-Man, it's a bootleg. It looks just like the Galaxian hardware bootleg versoin on MAME (notice the "CREDIT 0" in the bottom row of dots instead of under the maze, and only says "HIGH" with 1 line instead of having "1 UP, HIGH SCORE 2 UP" on a separate line over the actual score digits and the solid blue in the mazes instead of just thin outlines)
