Dave27
Ken you were right I'm impressed. It appears to be playing flawlessly now and all the quirks it had are gone. I pulled out the control center and the plungers worked great accept theres this spring loaded arm with two spring loaded little pawls on it and one of the pawls was very stiff and stuck. So of course I took the microscopic c-clip off and the little BASTARD spring cleaned all of it and put it back together and it functioned like it should. I checked all fuses which were good. I also cleaned the cable connections for the torrat memory or whatever its called and all appears good. Its been playing steady but I hope these are selections I chose yesterday that didnt play. The only thing I couldnt remember is the pawl has a small tooth that catches two other teeth wasnt sure which side it went on but it looks to me it didnt matter because everytime the selonoid actuates it puts it where it wants anyway. Now if someone has a picture of how the inside lock linkage hooks up for the glass that holds the labels that would be great...Thanks again.....Ken and all
