TFTC Ball Drain
killerbooger
Spokane, Washington
I have a Tales From The Crypt pin and when the ball is launched it hits the gilliotine targets and goes right down the drain. Just wondering what I can do to fix that. Obviously the skill shot is important so I don't want to alter the launch path.
Thanks a lot!
Maybe obvious, but you'll likely just need to level it out with the leg levelers or make a minor adjustment so it doesn't do that. My friend has a TFTC and this happened when the game wasn't 100% level. He has his incline set to about 5 degrees if that helps.
Ill check it again. I thought I had that part right but who knows. LOL! I have seen stranger things. I have moved it a little so maybe it is off.
