Talon2000
The Megatron trough cannon is having some sort of strange problem. It will sometimes see balls when they enter and sometime not. The switches work. Is there an alignment procedure or setup for the switches? Also when you get more than 3 balls locked, the solenoid seems to half fire 5+ times before shooting a ball out, and when it does it just sorta spits out the ball, most times two will come out (not a multiball mode). It works about 25% of the time correctly, as compared to the other TF pins I've played. Currently I have virtual lock on.
So I emailed this to Stern, and got this back.
"Your Megatron trough assembly might need to be widened. To widen the trough assembly you'll need to remove it from the game via 4 wood screws. With the trough assembly removed, pull the side out slightly (see picture)."
Hope this helps someone with cannon problems. It took care of mine.
