Tetris PCB Question
micksimmonds
Donor 4 years: 2011, 2013-2015
UK, United Kingdom
are there variants on the TETRIS PCB? I have 2 and one appears to run vert/hori regular config, the other pcb is always set to cocktail (head to head mode) regardless of both matching the same dips? I figured was the same pcb and you altered the cocktail/upright stuff in test/dips
anyone shed any light on this?
thanks
There are technically two Tetris pcbs: a cocktail board that runs on a vertical monitor, and a standard upright board that runs horizontally. However, you can swap the ROMs on any Tetris pcb to change it from a cocktail board to an upright board or vice-versa...
