Testing Williams boards
flynn54321
GREEN BAY, Wisconsin
I just got 3 complete bubbles board sets and a sinistar set. Can I test these in any of my other Williams games or are Williams boards not swappable ?? I have defender, stargate, robotron, joust, moon patrol etc
You can test the CPU, rom, and sound (except sinistar uses a second sound pcb) in your Joust, robotron, and stargate. The IO "wigit" pcb for bubbles and sinistar is set for a single optical joy.. So testing that one prolly won't work..
Good luck!
The Joust, Robotron & Stargate CPU board is not interchangable with the Bubbles ROM board.
You can plug in a complete Bubbles boardset in either a Joust, Robotron or Stargate wiring harness to test however....
Yes, it will hook up to the power supply and monitor.
If you hook up a Defender MPU and a Robotron ROM board, it won't work. You'll have to hook up the set "Robotron MPU, Robotron ROM and Robotron Widget board" You don't have to have a sound card plugged in to test the video.
-Muel
